Sony KDL-55W807C horizontal lines/rollover/ghosting
The TV is from 2016.
A few months ago the problem started appearing more and more right after turning the TV on. Most of the time it stopped and stayed away when turning it off and on again, but now that trick doesn't work anymore.
It looks like horizontal lines/rollover/ghosting and is wavering, also in the left corner of the screen there is a bright spot on and off clearly visible on a dark screen when booting up for example:
You can see it better in the video:
I also hear electrical buzzing around the tcon board, it seems to be a few seconds louder every time the lines appear.
I already reconnected all of the ribbon cables, no change.
Could it be the tcon board or is it more something like the LCD driver or power supply?
The tcon is a T550HVN08.4 Ctrl BD 55T23-C0G, see pic:
UPDATE: pics of bufferboard:
UPDATE2: close-up of the chips on the buffer/matrixboards:
left faulty screen half board U001:
right screen half board: U001:
@lektroflow this does not look like a common T-con board failure. Ty something like this. Unplug the power from your TV and disconnect one of the ribbon cables from the T-con board to the LCD buffer boards. Then plug your TV in and turn on your TV. You will only have 1/2 a screen but see if the anomalies are still there. Then try the other side. Disconnect power, reconnect the first ribbon cable, disconnect the other ribbon cable, reconnect power and turn your TV on. What do you get?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@oldturkey03 Thanks for the input.
Disconnecting one ribbon makes the left screen half (where the bright spot in the corner is) always white but the right half looks normal without anomalies this time.
Reconnecting it again and disconnected the other makes the whole screen white stripes and anomalies.
Swapping the 2 ribbon cables makes no change.
crwdns2934271:0crwdnd2934271:0 lektroflow crwdne2934271:0
