Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
Display Assembly Adhesive For iPhone 13 pro
Hi everyone,
I want to replace the battery on my iPhone 13 pro (A2638) and I just need the battery and the Display Assembly Adhesive (I already have the tools) however I can't find the adhesive for the 13 pro sold separately.
Should I use the iPhone 13 adhesive??
You don’t need to use the iPhone 13 adhesive—the correct iPhone 13 Pro Display Assembly Adhesive is available here:
👉 iPhone 13 Pro Display Assembly Adhesive
Since this one is specifically labeled for the 13 Pro, it’s the right choice. Just make sure to remove any old adhesive before applying the new one for a proper seal.
Good luck with your battery replacement! 🔧📱
crwdns2886500:0This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 13 Pro.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Hi rstranic, thanks for replying
Unfortunately it's not showing on the Australian store :')
Maybe it's out of stock
Hi,
After a quick search on Google, and Chat GPT, I found out that there are no actual differences in screen size between 13 and 13 Pro, besides that the frame is made from different material.
I would go ahead and get the 13 version. Even if it's not 100% the same, it is quite soft, and when you remove the plastic from the adhesive, you can maneuver it a bit, it wont stick too much before you heat it so don't worry.
it is much better than nothing (at least it will help for the dust).
Good luck!
Scarfm crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 285
