I need some help to fix
I have a sandisk cruzer glide and there is no power going to the board when it's plugged in. Can someone help me?
@petermozelewski see if you can add a larger picture so we can actually enlarge it enough to check traces and components. You will also need to post one for the other side as well. Have you checked the USB port with a multimeter already?
Sure I'll make an edit.
