I need to get a replacement vibration motor
I have a galaxy s24+ and the vibration motor broke after I dropped it. Dose anyone know where I can source a vibration motor. Thank you
Search for the loudspeaker, it's one unit. With the buzzer. I replaced mine and it made no difference, from what I have found is that the s24s have motherboard problems and I'm pretty sure that was my issue, I just ended up trading it in for the new 25+. But you might have more luck then me.
Oh that's a bummer, I'll see what I can do since if it’s a faulty motherboard since I might be able to get it replaced under the standard manufacturer warranty if that's the case, Hopefully they have the part in the authorized repair center because I remember I had an issue the Note 10 where there was no parts for it on any store authorized repair shops
Thankfully it wasn’t the motherboard in my case, and it worked perfectly after getting the new part. I really appreciate you taking the time to help!
@maximrebant the vibrator on this one is part of the speaker assembly. You can get it from places like this or even from here Ultimately, just do an online search to see if there is something in your geographical area :-)
To replace it, use this guide Samsung Galaxy S24 Plus Earpiece Speaker Replacement
@oldturkey03 Hi, I have a similar problem with my S24 but its not the plus edition, do you know where I could source that specific speaker/vibrator part from for the plain S24 5G? I can't seem to find it anywhere...
@cristianrod9202 I'll check for the part number as soon as I can. Let's see what we can find out. What Country are you located in? Just to make sure we hit the right geographical region ;-)
@oldturkey03 US, and thank you!
@cristianrod9202 it is in the speaker assembly for the S24 as well. Check places on here (of all the places we could have found it ;-) ¯\_(ツ)_/¯
Just ended up getting it. Thanks again! Just to confirm something, do you think it's ok for me to reuse the same adhesive or should I apply a new one when I open the device? I have never worked in a mobile device so I really don't know too much about the standard procedures. The guide you sent makes it look super straightforward though
its in main/loud speaker at bottom. u can see the 4 contacts
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 552
