The itel Vision 3 smartphone was released in 2022. It is powered by Unisoc SC9863A chipset, has up to 3 GB of RAM and up to 64 GB of internal storage (depending on model).
Why is the phone not booting?
If your Itel Vision 3 is not booting, there are several potential causes. Here are a few troubleshooting steps to help identify and possibly fix the issue:
1. Check the Battery
  • Charge the Phone – Ensure that the battery is not completely drained. Plug the phone into a charger and leave it for at least 30 minutes before trying to turn it on again.
  • Try a Different Charger – If the charging cable or adapter is faulty, the phone might not be getting enough power to boot. Try using a different charger or cable.
2. Force a Restart
  • Hold the Power Button for 10–15 seconds. This can sometimes force the phone to restart if it's stuck.
  • If that doesn’t work, try pressing the Power + Volume Up buttons simultaneously for about 10 seconds to see if it enters recovery mode.
3. Inspect for Physical Damage
  • Check for visible damage (e.g., cracks or moisture) that might be preventing the phone from booting.
  • If the phone was recently dropped or exposed to water, internal components might be damaged.
4. Boot into Recovery Mode
  • Try to boot into Recovery Mode by holding Power + Volume Up until the recovery screen appears.
  • If you can access the recovery menu, you can try options like Wipe Cache Partition or Factory Reset (be aware that a factory reset will erase all data).
5. Software Issues
  • If the phone was updating or installing an app when it shut down, there might be a software issue.
  • If the phone enters recovery mode, you may have the option to wipe the cache partition or perform a factory reset to fix software problems.
6. Hardware Failure
  • If the phone still doesn't boot, there could be an issue with the battery, motherboard, or other internal components, and professional repair might be needed.
If none of these solutions work, it’s best to contact Itel support or take the phone to a certified repair center.
Itel a50 ekran lhite
Aytel 50 ekran gelmiyor
After doing the battery connector the it not boothing
Anyanwu joy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
