Water pump replacement time
Water pump replacement timeframe
When it starts leaking or making noise. I'm not aware of any kind of recommended replacement interval like there is for timing belts or oil changes.
No problem, Kody. I don't know the details of your rig yet, but on my son's 1985 GMC High Sierra (K2500) with a 350 ci engine, it's a pretty straight-forward job. Once you have the belts out of the way it shouldn't take more than a half hour or so; add another half hour for the belt R&R and an hour should be enough time.
I meant the time frame to actually fix it not when to replace it my bad
Yeah sounds about right it’s a 98 but it’s also a 350 so I assume not much change besides maybe the water pump part itself but I believe they are in the same common area
@kodyarnold Yep, not that much difference in that area. If you've ever had to replace a water pump on these new models that use the timing belt to drive the pump, now there's a pain in the behind. I'd much rather have one out there sitting proudly on the front of the engine where you can actually get to it. On my son's truck I can climb on in the engine compartment to work on it.
crwdns2959996:0crwdne2959996:0 298
@kodyarnold what is the year, the model and what engine size?
crwdns2957956:0crwdnd2957956:0 oldturkey03 crwdne2957956:0
