Repair guides and support for cars and trucks by Toyota Motor Corporation.
2015 Toyota Hiace Commuter Very slow or sluggish acceleration
I have a 2015 Toyota Hiace Commuter and it recently developed the issue of very slow and sluggish acceleration accompanied by thick blue colored smoke emitting from the exhaust. Initial checks with an ECU diagnostics tool pointed to errors with Throttle Body. A new throttle body was replaced, and even after resetting this new throttle body with the diagnostics tool the issue persists...
@gideonfrancis what engine size does it have? Have you removed your sparkplugs and checked the faces of those? What do they look like? Have you tried a compression test? What are the actual codes you get when you scan your Toyota?
Hi @gideonfrancis
Check the engine oil level to see if it is going down significantly as it seems that the engine is burning oil when it shouldn't be.
Blue exhaust smoke indicates a problem with the engine e.g. leaking engine oil seals, worn piston rings, faulty valve stem seals etc.
Gideon Francis crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 41
