Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
My iPhone restarts every 3 minutes : missing sensor PRS0
I dropped my iphone 11 in water and from that moment it started turning off. I went to many services but they didn’t wanted to help
When i went to another assistance service they changed many pieces and the whole charging port . But it was from a damage phone that he bought for pieces. It still turned off after 3 minutes .
Now I don’t know if I should try again changing it from a different piece that is new or what Should I do to transfer the photos? I didn’t had a backup. I bought a new phone because i couldn’t use it anymore but I want the photos 😭
  • the display was already broke before and after I dropped it in water the screen was more damaged. They tried changing the screen , the battery , the Face ID sensor , the whole charging port but nothing
@alexandralulu PRSO is the barometer and it is located on the Charge Port Assembly. The issues with that are most likely Charge Port Assembly or its connector on the Logic Board. Getting used parts is always a crap shot. I would run the panic log once more and then post it on here with your Question. Use this guide Adding images to an existing question for that. Let's see what it tells you. You may just have to replace the charge port once more :-) but we will know more once you post your log. Read through this wiki iPhone Kernel Panics on how to get to the log etc.
My screen and display are broken :) I hope you can see
@alexandralulu es, it looks like it is still the same sensor. The difficulty here is that you have a water damaged phone, so it could also be the sensor connector and circuitry on the logic board. Have the people that helped you give it one more try with a different charge port and also ask them to check your logic board for any kind of corrosion damage. If you can't start your phone, you wont get your pictures from it.
Alexandra Lulu crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 187
