Turning off at odd times
Anytime I turn my laptop on, it automatically turn off after using it for a short while, and this keeps on repeating even if it is at 100 percent.
@ernestanokye could be a power issue but it sounds more like a thermal issue. It will turn off if it "feels" like it is overheating. I would suggest that at first you check the Windows error logs (I assume your are running Windows OS what version?) You will need to use the Windows Event Viewer to review those logs. this site shows you how to access those logs. Let us know what you fiend out.
Next you want to check your RAM. If you have more than 1 memory module, try to run it with one and see if it still turns off. Then try the other one. See if that makes a difference.
Ultimately, I would open the bottom cover and clean the air ducts and the fan. Most likely I would even replace the thermal paste. Again let us know what you find out,
crwdns2942667:0crwdne2942667:0 62
