Guides and repair information for cars and SUVs manufactured by Kia Motors
04 amanti crankshaft sensor position
i had a code for.crankshaft sensor ,so i could not find where it was located , an found it in the timeing belt on bottom part if.the engine., i replace.it but it did nothin now at first it was barely drivable well now it came out wit throttle position sensor an a 2011 is there a chance i put it in upside down what position should it be in
You said you replaced the ckps, correct? The ckps is located near the bell housing on the opposite side of the engine from the timing belt, as indicated by the alldata diagram. If vehicle is still running rough after repair, check your timing and make sure timing didnt jump. I had a kia sedona recently that was throwing codes for a ckps, but none to indicate that the cam crank correlation was actually out. Come to find out timing was several teeth out. If timing is good, I would check throttle body itself; kia has a lot of throttle body issues
Juan Enriques crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 17
