Repair guides, disassembly, and troubleshooting information for the Google Pixel 9 Pro XL smartphone, announced August 2024. Model number GGX8B.
Google pixel 9 pro xl bottom mic membrane
Today I decided to opened my Pixel pro 9 xl which it got voided by warranty because of the moisture damage and I saw that the bottom microphone membrane has a hole. Is theres a way to replace it? Do you guys have a parts available for it, I tried to remove it and it looks like it was glued, and i dont know if the microphone in pcb is damage too or it just the mesh on the membrane that is damage, because when I blow air on the hole before opening it, it is picking up some noise like tapping noise and air noise but it cant pick up my voice. I hope there is a way to fix this
The photo is not my original photo it was from a tear down video in Youtube, but my indicator was totaly red and it also has that hole from the membrane. Please help thanks
I'm sorry to hear about the issues with your Google Pixel 9 Pro XL's bottom microphone membrane. Addressing this problem involves careful consideration, as the microphone assembly is a delicate component. Here's what you can do:
1. Assess the Damage
  • Microphone Membrane: A hole in the membrane can allow debris or moisture to enter, potentially affecting audio quality.
  • Microphone Component: If the microphone isn't picking up your voice but detects air or tapping noises, the internal microphone might be damaged.
2. Replacement Options
  • Microphone Assembly: Currently, specific replacement parts for the Pixel 9 Pro XL's microphone are scarce. iFixit offers various components for this model, but a dedicated microphone part isn't listed.
  • ifixit.com
  • Third-Party Suppliers: Some vendors, like Maxbhi, list a "Microphone for Google Pixel 9 Pro XL." However, availability and compatibility can vary.
  • maxbhi.com
3. Repair Considerations
  • DIY Repair: Replacing the microphone membrane or assembly requires precision. Given the component's fragility and the risk of further damage, it's advisable only if you have experience with smartphone repairs.
  • Professional Service: Considering the potential complications, seeking assistance from a professional technician or an authorized service center is recommended. They can accurately diagnose the extent of the damage and perform the necessary repairs.
4. Preventive Measures
  • Protective Cases: Using a case that shields ports and openings can help prevent future damage from moisture or debris.
  • Regular Maintenance: Keep the device clean and avoid exposing it to environments where it might incur moisture damage.
In summary, while direct replacement parts for the Pixel 9 Pro XL's bottom microphone membrane are not widely available, professional repair services can offer solutions to restore your device's functionality.
Thank you Andria, I think the microphone is ok since I was hearing a hissing sound and some tapping noise, I wonder if the membrane is actualy the one that got damage and it is like an eardrum when it gets broken it could turn you deaf. I check the entire microphone and power charging pcb there is no visible water damage, but the moisture indicator for the membrane was totally red. I hope one day there's a method to fix that part of the cellphone. I can still use the phone normaly for calling and recording videos, but the stock video apps can only record 1 side of the audio depends if you use the front or the back camera, so what I did is I downloaded an apps called blackmagic camera to record my video and they have an option to use which mirophone you want to use in recording and also it gives me an option to set it mono or stereo, when I choose mono it fix the microphone one side feed problem, but with the stereo is other way around. I think im gonna live with this. Thank you again for the reply. Take care
Hi I have issues with my microphone the only way I can make calls is but using the top microphone but for all other functions I have lost I could do with getting this fixed
Positive Vibes crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 992
