Board change leading to Shifted image
I changed the board on my Ferguson F5820TRS4K with a HK.T.RT2861V09 board with a board of the same number. Exactly same type of board. But now the image I get appears shifted to the right and continued on the left. What can I do.
@seiduseun you are not telling us what the picture showed before you replaced the board or even if this is a new or used board. If it is a used board, the issue maybe the firmware being setup for a different TV (size, panel etc) You can always try to reinstall the eMMc firmware and see if that change anything.
Thank you. It was dead and didn't show anything when it was detected that a change of baord would sort it. It's a board I got from Ali express and it's said to be new on there.
@seiduseun some TV's require to have the firmware updated whenever new boa are installed. I'd start with that.
Hiya. Thank you for comment. I reached out to Ferguson and got the firmware from them and now it's all fixed up and working.
@seiduseun perfect! I like it when a good plan comes together. Glad you got it fixed.
Repair is War on Entropy
seidu seun crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 36
