A portable bluetooth speaker that was first released by Bose in 2021.
Not charging anymore after being dropped in a pool
I dropped it in a pool it worked fine after but then it shut down i waited till it was dry to charge but it won't charge anymore
Hi @raidenlingat
The speaker has an IP67 rating which means that it should be waterproof, but this was when it left the factory so something must have happened to its waterproof integrity since then, as it should have survived being immersed in water for a short while.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your speaker and then remove the battery as soon as possible from the speaker to minimize any further damage.
Then you need to dis-assemble the rest of the speaker and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the speaker might possibly work correctly again.
Here is the ifixit Bose Soundlink Flex repair guide that may help.
If this process seems too daunting, take your speaker to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
alluka crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 136
