Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
motherboard damaged following disassembly
Hello,
I removed the motherboard for a CPU change, during reassembly I tore off a component, could someone help me identify this component and maybe tell me where I can buy it. Thank you
This a data choke for the Ethernet port. It's identical to the one to the left of the one torn off (not that probably helps much, but just as an FYI)
On the schematic its marked as HCMC0805-4SM and 370 ohm. I haven't been able to find anything that's exact, but if you don't use the Ethernet port you can also get along without this (although I definitely understand wanting to replace it)
Hello, a very big thank you to you. Thank you
ss0pc3vz crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68
