Why my Saki Gooseneck kettle is not heating up?
Hi people 😊 hope I will get some answer here as I don’t want my kettle to end up in the land-field.
My Saki Gooseneck kettle stoped heating up. The base is working, showing the temperature settings and sensing that the kettle is on, but it doesn’t start to heat up the water. I tried to find the answer everywhere but i couldn’t find any threads with this particular kettle.
I hope someone can help me here 😊 as I read what could be the reason a lot of people suggesting thermal fuse.
I’ve opened the bottom bit of the kettle and I’m not sure where I can find it ?
I will try to send photos.
The kettle is temperature adjustable one.
Thank you so much for anyone who would be willing to to help me ✨
This kettle has a base, right? There are a number of possible causes of you problem.
There could be a problem in the connections from the base to the kettle - cleaning them up might help.
It could be a thermal fuse - though in this config I wouldn't think it would be in the base.
It could be the heating element in the kettle - that would likely be non-replaceable.
It could be the temp sensor in the kettle - tha would also likely be non-replaceable.
Bottom line, you will need to trace it out with a multimeter to find the disconnect.
Mag Rad crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 240
