Why is my laptop no power
Why my laptop have no power
@mreretenato6560 it will help if you can add to the 6 words you've used to formulate your question. Things like what you have checked and what you have already tried, would be nice and useful. It will also be of paramount importance that you properly identify your computer. We will need to know the exact model number.
For now, you want to start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 20
