Released in May 2020, the 13" MacBook Pro features quad-core Intel 8th generation Core i5 and i7 processors, and Intel Iris Plus 645 integrated graphics. (Model A2289/EMC3456 with two Thunderbolt 3 ports)
MacBook Pro 2020 not charging
My macbook pro has not been properly charging for about a month now. This occured randomly (No damage to the laptop), with both ports stopping working at the same time. If shut down and left on the charge the laptop will charge slowly, taking about a week to fully charge.
I have tried:
  • Restarting laptop
  • Different chargers and adapters
  • Cleaning USB C ports
  • Manual NVRAM reset
  • Disconnecting and reconnecting battery
Earlier today the laptop recognised a flash drive I connected and I could see the data on it, but it still would not charge or recognise a connected charger nor was it able to charge another device. However after runnning diagnostics and taking it to a repair shop where they disconnected and reconnected the battery it no longer recognised the flash drive.
I am just wondering if anyone could identify what the problem could be, and whether it is fixable or not.
Hi,
Using a USB-C power meter you can measure what kind of voltage and amperage is negotiated between charger and laptop. Most online troubleshooting guides will start from there. It sounds like one of the power converting IC's or usb-c communicating IC's is not doing it's job. But without opening the laptop and checking where the voltage gets pulled low or is shut off by some component, it's hard to tell. This channel has a lot of MacBook troubleshooting/fixing:, maybe your problem is reproduced on there: https://www.youtube.com/channel/UCl2mFZo...
kailan crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 83
