Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Touchscreen's left edge does not work
As the title suggests, left edge doesn't work top to bottom. For example you can't type q while using the keyboard.
I took the thing apart and found out that there were some corrosion-y stuff on the display flex cable thing right under a small black sticker. I peeled it off, revealing 4 solder pads and cleaned out the gunk - still the same, no improvement. At least it didn't go out completely!
Can I salvage this display in any way? I really want to keep this device original.
Edit: Left edge DOES work sometimes but only for a shortwhile. The screen will go unresponsive for a second and then the fault area won't respond to touch again.
EDIT: I should add that I'm the second owner of this device and thus I don't know the precise history of it. IOS shows no service history but it might have been dropped (scuff marks on case.)
EDIT: Pictures of what I found:
I tried to clean the pads and the result:
Last image is how it's supposed to look like according to iFixit.
The corrosion on the display flex cable area suggests possible liquid damage or oxidation, which might be affecting the touch signals.
It's not clear from your description exactly where the corrosion appeared; was it on the phone or on the display? Either way it's concerning as there should never be any corrosion inside a phone, but if it's on the screen then I would strongly suggest your next step should be to replace the screen.
Fortunately your phone is one of the last ones Apple made that doesn't have the screen paired to the motherboard so you can replace it without getting a warning that the screen might not be genuine - even if it is. You will, however, lose your True Tone function unless a small piece of data called the MtSN is copied from the old screen to the replacement. Any phone repair store should be able to do that, and it will get copied as part of the system configuration if you use Apple's self repair program. You can buy a programmer yourself, but even I would hesitate to spend around $85 USD for something you might only ever use once.
If possible you might add pictures of the corrosion to your question; there are some very experienced repair technicians on this site that might be able to tell if it's a problem or not. If the corrosion is on the motherboard that would be extremely concerning and may require board level repairs that would be beyond the ability of most of us home DIYers.
Adding images to an existing question - iFixit Repair Guide
I will add the pictures I took as an answer.
Added as edit.
Since you found corrosion under the sticker, it's very likely either the flex cable, solder pads, or logic board traces are damaged. If you've cleaned and inspected everything but still no response on the left edge, a micro-soldering repair or screen replacement is the next step.
I will add the pictures I took of the corrosion as an answer.
Added as edit.
Amateur Disassembler crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 72
