The Poco M3 Pro 5G is an entry level 5G Android smartphone which was released in May, 2021. It offers a 6.5" IPS LCD, a 5000 mAh battery, a 48MP main camera and runs on a MediaTek Dimensity 700 chipset.
Auto switch off problem
Why my phone is repeating auto switch off
It gets restart after playing speaker or sound
  • Battery Problems: If your phone's battery is damaged or worn out, it may not be able to provide a stable power supply, causing the phone to turn off randomly.
    • Solution: Try charging your phone to 100% and see if it powers off even when fully charged. If it continues shutting down, the battery may need to be replaced.
  • Battery Calibration: Sometimes, the phone might incorrectly detect the battery level, causing it to shut off even when there's still charge.
    • Solution: Try draining the battery completely (until it turns off) and then charge it to 100% without interruption. This can help the phone recalibrate the battery.
2. Overheating:
  • Excessive Heat: If your phone is overheating (e.g., due to heavy usage, direct sunlight, or resource-intensive apps), it may automatically shut off to protect the internal components.
    • Solution: Turn off the phone and let it cool down. Try using it in a cooler environment, and avoid running resource-heavy apps that might cause overheating.
3. Software Glitches:
  • System or App Malfunctions: A corrupted system file or a malfunctioning app can cause your phone to turn off automatically. This can happen after an update or after installing new apps.
    • Solution: Try restarting your phone in Safe Mode to see if the issue persists. If it doesn't, a third-party app might be causing the problem. You can then uninstall apps one by one to identify the culprit.
    • Clear Cache/Data: If you suspect the issue is software-related, try clearing the system cache or perform a factory reset (note: a factory reset will erase all your data, so back up important files first).
4. Hardware Issues:
  • Loose or Damaged Internal Components: Sometimes, internal components like the power button or the motherboard may have become loose or damaged, which can cause random shutoffs.
    • Solution: If you're comfortable with it, you can open the phone (or take it to a technician) to check if anything is loose or damaged. In some cases, replacing a damaged component may resolve the issue.
5. Faulty Charging Port or Cable:
  • Charging Issues: If your phone is connected to a faulty charger or charging port, it may intermittently disconnect, causing the phone to shut off unexpectedly.
    • Solution: Try using a different charger and cable to see if the problem persists. Also, inspect the charging port for debris or damage.
6. Firmware or OS Update Issues:
  • Update Problems: If you've recently updated your phone's software (such as an OS upgrade or patch), there could be bugs or incompatibilities that cause the phone to turn off.
    • Solution: Check for any pending updates or patches that may address bugs. If you're on a custom ROM or beta version, consider reverting to a stable version.
7. External Factors (SIM Card or SD Card Issues):
  • SIM Card/SD Card: A faulty or improperly inserted SIM card or SD card can cause random shutdowns.
    • Solution: Try removing the SIM card and SD card to see if the phone still shuts down. If it doesn't, you might need to replace the card or check for any physical damage.
8. Factory Reset (Last Resort):
  • If none of the above methods work, and the problem seems to be related to software or settings, a factory reset may help resolve the issue. Remember to back up all your important data before proceeding with a reset, as it will erase everything on the phone.
Try Safe Mode: This will allow you to boot up the phone without any third-party apps running. If the issue stops, it's likely an app causing the problem.
Test Battery and Charging: Check whether the phone shuts off when it's connected to a charger.
Check for Overheating: Ensure the phone isn't overheating due to heavy usage or external factors.
Visit a Technician: If you suspect hardware issues, like a faulty battery or motherboard, it's best to visit a professional technician or service center for a thorough checkup.
@stuartshort
Please take note of the ifixit guidelines when using AI to answer questions as it's beginning to look like you're just copying and pasting AI generated answers to questions.
Remember you are responsible for conveying factually correct information.
If you persist in doing it this way, then your answers will be deleted.
Moderator.
Rahul Ahmed crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 255
