Repair and additional information for the GE GSS23WSW*** refrigerator, a side-by-side model without an ice through-door feature, equipped with an automatic defrost and an anti-sweat heater switch. This page covers information for model numbers matching the pattern GSS23WSW***.
Water dispensing issue - door feed seems clogged
The water is not dispensing from the door. Ice continues to be made. I changed the filter and the valve with no improvement. I decoupled the water hose at the bottom of the door and water is being delivered to the door. I am guessing there is no additional valve from the bottom of the door to the dispensor.I fished a wired from below through the dispensing hose thinking it was glogged - got through most of the length - no improvement. Could not fish it through the dispensor itself. I tried (using a waterpik) to fill the hose with white vinegar. It not not take any from above. Any ideas?
GSS23WSTA SS (side by side)
I have removed "stuff" from my dispenser right at the tip of the outlet hose with a small knife or other small probe.
Thank you. I reemed out the top of the dispesing hose (did not seem clogged) with a stiff insulated wire. It only went in about 1/2" past the bend. From the bottom, I was able to push the wire up the door near the dispensor.
I fixed this by connecting 40psi of air through the bottom connection, then took a good 2ft piece of .155” weed wacker line through the nozzle in the door and pushed it through until the air escaped. Required a decent amount of elbow grease, and thought I was actually running into a tee/corner in the door. Continued to feed line through until I ran out, then connected the water back up to verify the clog was cleared.
Mark Creery crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 61
