Repair guides, manuals, and troubleshooting help for Redmi 9T. Get everything you need to repair your Redmi 9T yourself.
My phone cant turn on
first i think my phone just low batery and turn off so i go to charge it. after that i want to turn on my phone. i just press the power button. is dont turn on like normal but its just blink and turn off again
What have you checked so far? Have you verified your charger and cord are working? Have you checked the port for dirt or debris, and tried cleaning it?
Try doing a hard reset with the charger plugged into the device. You can do this by holding + Power button + Volume down hold them down for about 15 seconds then try pressing the power button after 15 seconds. hope this works goodluck
The problem is quite widespread on the Internet. The problem is quite common, there is already information about this problem somewhere on the Internet. If this is exactly the problem, there is a possibility of a short circuit on the motherboard if you put the phone screen down to the bottom, then after disassembling, removing the case(s) on the motherboard from the bottom left there will be a small screen (the so-called screen) most likely it can short out, I have not encountered such a problem myself.
amzar kacak crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 332
