The best way to remove the remaining battery adhesive
My Dear Community!
I successfully managed to remove the battery for an iPhone 11 that I am currently refurbishing and saving. My only problem is that after the battery removal there is still very very strong glue on the metal area that I tried to scrap off with my spudger for almost 2 hours and using 99% isopropyl alcohol but I don’t know what am I doing wrong.
Should I keep it soaking in the alcohol and after use the spudger or should I use a different chemical?
Thank you very much for your response!
Have you tried heating it a little with a heat gun on lowest settings?
Hi there @dinoo_fixit !
I did not try heating it but what I realised is that I didn’t leave the glue in alcohol for too long. The next day the whole area where the battery adhesive was dry and it became easier to scrap it off.
@mrkovacs I'm glad it worked :)
