Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
After changing the battery my MacBook Pro won't boot up
I changed the battery on my 2018 macbook pro with a kit from Ifixit and now it's dead. It won't even try to start. I have dual boot with a one partition having windows and the other partition mac os. Before starting the repair, I set the mac os partition to be the automatic side to boot up and then followed the instructions to turn off the auto boot. The old battery was swollen and giving some problem but it had been working. The repair went perfectly, so I can't figure out what's wrong.
Check the MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable is not damaged as well as the ZIF connectors are latched per Step 1 in this guide Recognizing & Disconnecting Cable Connectors here after re-inserting the ribbon cable we need to carefully fold the latch down to compress the cable.
crwdns2886500:0Replace the small flex cable that connects the battery daughter board to the logic board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
I checked that connection and the other ones too. Everything is fine. Can the cable be damaged even if it still looks good? I checked the battery voltage after charging it for an hour or two and there was no increase. So I don't think the battery is getting any power. Is it possible that something happened to my logic control board when I took it out?
@jms83415 - Over bending and sharp creases can damage the cable. Could you have damaged to ZIF socket? Post some pick on the connections here so we can see get in tight with lot of light.
As the battery was swollen and if the battery had already been replaced before then it’s possible the charging logic within the logic board is having issues.
Let’s get a better view of things install this gem of an App CoconutBattery post a snapshot of the apps main window here as well.
jms crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 114
