Trouble starting snow blower each winter
I have a 2 stage 24 inch electric start. It is about 5 years old. Although each winter it has been difficult to start, this year seemed hopeless, in spite of Stabil added to the high octane gas. First, the starter motor balked, but tapping lightly with a hammer while starting worked (you can remove, open up and sand the corroded parts lightly and it will work!).
It is an incredible pain to get at the choke. There is no air filter, so no need for an access, and the air intake needs to be shielded from snow, so although reasonable, the design makes it no fun to get unto the carb,.
I called our small engine repair shop. No help. BUT, if you look under the black enclosure, you will see a steel tube hanging down with a 10 mm bolt. Turn off the gas flow from the tank to the carburetor. Then, If you remove the small bolt and pump the primer bulb, you will drain the carburetor cup, where water and old gas can be the cause of the non-start. Then replace the bolt, turn on the flow, and with luck you will be able to start the unit. This was from a Youtube clip, and it saved our hide!
