Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
Any way to fix overheating logic board of iPhone 12 Pro?
Hi,
i bought a defect iPhone 12 Pro to harvest the Screen. The iPhone seems to be brand new.
The defect is, that it overheats (see marked spots in picture) while in use and gets fairly hot while off (including not normal battery drain while off), also the bottom loudspeaker is not working. Everything else works.
Someone before me seems to have swapped the battery for an aftermarket one (and soldered the old battery-chips to the new one). Everything else seems to be OEM and untouched. No water damage.
Here is what i already tried to narrow down the problem:
  • Swapped bottom loudspeaker - still no sound
  • Disconnected both connectors to the charging port assembly (including bottom loudspeaker) - no change still overheating
  • Swapped battery - no change still overheating
  • Display works fine in second iPhone (non pro)
This is an issue with the logic board (and probably the audio driver chip), right? Or does anyone has other ideas?
If I buy a new logic board, I still need matching FaceID assembly and Lidar to get everything working even with iOS 18 repair assistant, right?
Hi,
A new logic board will indeed require a matching proximity flex and FACE ID module (both are paired to the mother board).
If you want to use this as an entry into microsoldering, you could try to search for the broken component. From the history of the device it sounds like an IC, resistor or capacitor was nicked off while the battery was being serviced. Your best bet would be to look on the topside of the board around where the battery would sit.
good luck.
Alex crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 310
