The second generation of Scion's box-shaped hatchback.
Why is my window washer only squirting on the rear window
why is my window washer only squirting on the rear window. what needs to be replaced?
@unclegabe that all will depend on what you have checked. This could be an issue with the washer fluid motor, connector to the water tank. Check your fuses. You also want to rule out that it is a clogged line and clogged spray nozzles. Disconnect the hose that leads to the jets. Then try and if your have water coming out of that hose, it is your nozzles.
Uncle Gabe crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 49
