The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
Why does my cellphone still turn off after charging?
I have charged it to 100% percent as shown in the battery notification.
But when I unplugged the charging cable because I wanted to use my cellphone it turned off and the battery notification was 0%
Hullo goodevening,
how long have you had the phone for? is it always on charge? when do you start charging it from? 10% or 70%.
could be a battery fault or physical problem if so then replacing it would be the easiest option.
other quick tests could be Battery Calibration:
  • Let the battery drain completely until the phone shuts down.
  • Charge it to 100% without interruptions, then restart the phone while it's still plugged in.
Reset the Phone:
Perform a factory reset (after backing up important data) to rule out software problems.
only do this if you have a backup but make it a last resort
Use apps like AccuBattery to check the battery's health. its not perfect but could work
goodluck
Joy ajh crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 148
