Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
Any way to pair or replace the LiDAR scanner successfully?
I bought this phone second hand and apparently the housing was swapped at some point, and the LiDAR scanner wasn't transferred. I've successfully paired my battery, display, but the back camera still says non genuine. The pairing for the back camera can't be done, as it uses the LiDAR and it immediately fails, and boots you back out. I've been unable to find any way to replace it, and even iFixit has a guide, but doesn't address said parts pairing.
Is there any way to replace the LiDAR without the original part? It's a bit confusing how you can replace the back camera with a genuine part and still be unable to pair it because of the scanner, which I can't find on the selfservice website Apple put up.
Any help would be appreciated. Thanks!
https://www.aliexpress.com/item/10050043...
Sure, but as said before it's paired to the phone, so just replacing the part would do nothing, my phone has a LiDAR scanner in it, it's just not paired.
@nar001 does it not show in parts and service under settings
@tech_ni Nope, the LiDAR isn't one of the parts that show up there, only the back camera, that I can't pair because of said LiDAR scanner
@nar001 might be possible with jc programmer to program a lidar
Nar001 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 189
