My pc shows no signal and pc turns on
Ive had a my pc for a about 2 years I have a gtx 1660 super 1 fan and when I start up my pc its shows no signal I've checked every cable different monitor nothing works after I push the turn on button on the pc it beeps once then no display or anything just black screens the gpu fans don't spin at all once I boot it up I don't know what to do I'm planning to buy a display port cable to see if that fixs it any help please.
Hi @mosenicholson
What is the make and model number of the PC or the motherboard if a custom build?
Its a hp pc renewed I bought it from amazon the model number say the serial number is 4cv40197p5
Hi @mosenicholson
As best as I can find out based on the serial number that you posted, the desktop is a HP Compaq Pro 6380 Base Model Microtower PC.
Are you sure that it is turning on and booting into the OS and not just starting and failing to pass POST (power on self test), therefore not booting into the OS? Starting and booting are two different actions. Sequence is, PC is turned on, it performs POST and if all the hardware is OK then it boots the OS into loading the operating system
With HP desktops mostly a single beep on startup indicates a power problem or sometime a ram problem if it is a long beep.
Try the following and check if any of them work to get the desktop starting, passing POST and booting with a display or even getting into BIOS on startup with a display.
i. Perform a power refresh.
Turn off the PC if it is on and then disconnect the power cord from the PSU. Press and hold the PC Power On button for 20 seconds and then release it. Reconnect the power to the PSU and check if it turns on.
ii. If still no good, try a full power refresh.
Turn off the PC if it is on and then disconnect the power cord from the PSU. Open the PC case and locate the coin cell RTC battery on the motherboard and remove it from its holder. When it is out measure its voltage. If it is <2.5V DC, replace it. The battery model number should be printed on the battery itself. Usually they're a CR2032 Lithium coin cell, available most everywhere.
Reinsert the RTC coin cell battery (or its replacement, into its holder on the motherboard (+ve side up as marked on the battery), reassemble the desktop, reconnect the power to the PSU. Reconnect the power to the PSU and check if it turns on.
If it does turn on with a display, there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default setting. Once the date and time have been corrected the message won't appear again the next time the PC is started.
iii. If still no good, looking at the specifications and images of the PC's PSU it seems like it is an ATX type PSU and not a proprietary HP PSU. If this is correct use a DMM (digital multimeter) to check if all the voltages being supplied by the PSU are correct by performing a paperclip test on the PSU.
If still no good and if you can't even get into BIOS with a display, then there's a motherboard problem.
Mose Nicholson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 48
