Released In December 2022. A Laptop equipped with a Intel Core I5 11400H And A GTX 1660, RTX 2080 or A RTX 3050 TI Also Equipped with 512 GB Of storage, 16 GB Of DDR4 Replacable Ram And has a 2nd M.2 NVMe slot, A 144 Hz 1080p screen, RGB Keyboard and 2 HQ Speakers With DTS.
Why is it lagging on battery use
whenever i use my laptop on charge it lags i get 20 fps in games like valorant please help
Hi @abhinabasharma
It may be that the battery is starting to slowly fail and can no longer maintain its charge as it did before, so the laptop hardware is struggling.
Create a battery report to check the condition of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as seen in the report. For a good battery they will nearly be the same value.
You can determine the condition of the battery as as percentage by using the formula Full Charge Capacity value x 100 ÷ Design Capacity value.
If the percentage is <35% you may consider replacing the battery.
If you decide to do this, here's a video that may help.
Search online for 0B200-03270100 to find battery suppliers that suit you best. This is the Asus part number for the battery. It should be located somewhere on your battery if you wish to verify.
Get on armoury crate and change battery saver to standard
This model of the TUF laptops dont use the full potential of the dedicated graphics card. Instead it uses the intel IGPU. It doesn't have a mux switch. So if you want the full power then plug your laptop in.
ABHINABA Sharma crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 249
