Hi Kaine!
Ah you mean the D-pad!
For this you do need to open up the console, but it's really easy to do!
You might want to replace the rubber and clean it there. You do NOT need to remove the motherboard, only the power board to access the d-pad button and rubber.
Clean the power board carefully (and the d-pad conductive buttons on there). And the d-pad plastic button as well. Replace the rubber for a new one and it should be good to go!
Guide: Nintendo DSi XL D-pad Replacement
Part: https://www.ebay.com/itm/354393945198
With this guide, you can determine if you want to do it by yourself or let someone else do it for you.
If one of the conductive pads failed, damaged and could not be cleaned anymore, I advise to fully replace the power board. Easier then soldering the conductive pads off. That part can be found here: https://www.ebay.com/itm/354118222468?_t...
But try cleaning first! Most of the times this will fix it.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Hi!
Which stick do you mean actually? The DSi doesn't use any joystick.
crwdns2934271:0crwdnd2934271:0 koppie007 crwdne2934271:0
My bad i mean the analogue button like the left right up down button, it’s sticking so it’s always pressing right
crwdns2934271:0crwdnd2934271:0 kaine roberts crwdne2934271:0
