I think my injectors are bad
I think my fuel injectors are bad
Did you check for a blown injector fuse? Blown fuel pump fuse? Check all fuses, then if the engine won't start, remove spark plugs and examine them for raw fuel and fuel smell. Try a spark test to verify spark or after putting plugs back onto the engine, spray starting fluid into the throttle body and try starting. Either the engine sputters to life or not. A brief start indicates a fuel system problem. Failure to start from starting fluid can be one of two faults; ignition system fails to generate spark or a faulty crank sensor. A faulty crank sensor will not allow the EFI system to; operate injectors, ignition system for spark and prevent the fuel pump from operating.
crwdns2942667:0crwdne2942667:0 14
