Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
3ds starts drifting after a few minutes of playing
Hello! My new 3ds starts drifting after a few minutes of playing. First it works fine but after a few minutes the (I think analog stick) starts drifting to one side very aggressively. i’ve tried cleaning up with iso, but then the problem still occurred so I replaced the analog stick and i still have the exact same problem. I don’t think it is the c-stick since this also happens in games that don’t support the c-stick. I’m pretty sure that i put the ribbon cables right in and didn’t damage it since the rest of my console still works and i did it very carefully. Does anyone know a solution?
Just to check, have you tried calibrating the circle pad?
yup, i did. didnt work sadly
Maybe something on the motherboard. Do you have any other 3DS there? Swapping out the stick would be a great test. It does sound like the issue is there on motherboard level...
I would give a shot at cleaning the Dpad registers, you could have some gunk causing "drift" as they are connected input wise. And if that's the case the issue was never your stick to start with.
marleentuuuh crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 218
