Repair guides and support for sinks, taps and faucets in your kitchen or bathroom.
Kitchen faucet aerator replacement
Hi all.My kitchen faucet aerator needs to be replaced.Can't figure out what parts I need so forth.
Hi @ag8079305
What is the make and model number of the faucet?
If you remove the rubber o-ring above the white plastic aerator (as seen in the first image you posted - part on left side) then the aerator should come out.
Here's a link that may help.
Complete aerators i.e. aerator and housing, usually the housing comes in two types, male and female. Those that have a thread that screws into the faucet spout and those that are screwed onto the faucet spout.
Looks like yours is a female thread aerator. Mostly spouts are of a similar diameter so you should be able to find replacements at any good hardware or plumbing supply store.
(click on image)
crwdns2944067:09crwdne2944067:0:
It's a glacier Bay not sure exact model though.
@ag8079305
Did you get the white plastic aerator out OK?
You may have to take the complete aerator assembly to a plumbing supply or hardware store and see if you can find a match.
Yes I was able to remove it
@ag8079305
Usually they don't need replacing unless they're damaged.
If the water isn't coming out OK mostly they're just clogged with sediment/grit that builds up over time.
Sometimes the o-ring needs to be changed though.
The aerator itself is a little gross but the other part that it attaches too.The part on the right in the top picture.It is damaged.Not sure how overtime I guess.
crwdns2934275:04crwdne2934275:0
Ag80 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 232
