Display staying black after part replacement
Hi, I opened my Galaxy Tab S 6 Lite Wifi/4G to replace the USB port. The new USB port worked just fine, but unfortunately I tore off a small connector going to the display. (Not the main display cable.)
So the tablet turns on, but the screen remains black. In some guides I saw, there was only a main cable going to the display, not this small one.
Can I just order a standard display for Galaxy Tab S 6 Lite Wifi/4G to replace the display?
@shu26842 your images are really not focused enough to determine which part got damaged. If it is the board connector then you need more then the screen. If it is the ribbon cable, then yes, a display change will fix this.
shu crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68
