Hemodialysis machine is a machine used in renal unit in the hospital, to remove from waste from patient blood who has kidney problem.
Nipro NCU18 valve movement eror
When i start the dialysis or cleaning matching screen show valve movement error
@mdniyamot This answer is for your information only. The valve movement error is a pretty generic error. It only reports that a faulty valve state is detected, but it does not give you any indication which valve. You may need to consult your local BioMed person or work through the valve state by using the NIPRO NCU 18 Service Manual I'd start by checking the water and flushing valves.
Since you are working with a medical device that can do harm, if improperly maintained or repaired, you definitely want to consult properly trained personnel. The first rule with medical devices must always be our core principle "First do no Harm"
Md Niyamot crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 164
