Ambilight not turning on
Hello,
I’ve got a 75PUS8506 Philips Ambilight TV and the backlight is not turning on. I noticed that if I press in the back of the TV just above the connectors, the Ambilight turns on, but turns off again when I stop pressing on that area. I’m not sure if it’s a heat sink or a cable that’s a bit loose. Wondering if it’s easy enough to take off the back panel to have a look and if it is any of those issues, how easy it is to fix it myself? Thanks
@buddhajon not sure about easy since this is a big TV and the back cover is a bit of a challenge. Get somebody to help you with removing it due to the size. Once it is removed, take a look at the boards and check for lose components etc. Take some well focused pictures and post those with your Question that way we can see what you see.
Adding images to an existing question
BuddhaJon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 77
