Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
My iPhone 10 was submerged in water briefly .
Question
I hope you can answer my question . My iphone 10 was submerged in water briefly .
I removed and placed in my car. I turned it on to make a phone call and thought that I might have dodged a bullet.
After that it went off again and after 3 days comes on for a few minutes and then goes off again . It has only 3% charge as the battery /red line icon came on so I thought it would be safe to charge.
I'm not sure if this is permanent damage or it is still drying out . I have removed the sim and placed it in container with silica to help absorb the water
Hi @smiley193523
Check the status of the LDI (liquid damage indicator under the SIM tray - see image) to verify whether water has penetrated the phone or not.
(click on image)
If the LDI has turned red then the phone will have to be opened to be cleaned and checked for any damage to the components.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone X repair guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Smiley1 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 51
