Repair guides and documentation for the Google Pixel 6a with 5G smartphone. Released in July 2022.
Glue for screen seam and plastic frame
Hello everyone, I'm going to change a battery on my phone. Looks like battery is very isdegraded and the screen is detached from the plastic frame, please check Figure 1 below. I've pre-read documentation, how to de-assembly the phone, and noticed that I will have to pry under plastic frame (Step 2 - Screen removal information).
I'm going to detach screen and then detach plastic frame. And of course I will need to glue the screen and this frame.
Which glue is applicable in that case? I heard about P7000, but decided to ask, if it's applicable for such case.
Figure 1
Hi @pavel80282
In the ifixit guide that you linked, scroll down to kit contents. It shows that Google Pixel 6a Display Adhesive - Genuine is available from ifixit.
crwdns2886500:0This custom cut adhesive film secures the display panel to the frame of a Google Pixel 6a smartphone.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$3.99
crwdns2944067:08crwdne2944067:0:
Please check the documentation. My case is red - screen seam, and it was detached by degraded battery. I have case with detached screen from plastic frame, and probably this Display Adhesive is not applicable for glue the screen and plastic frame.
@pavel80282
Maybe I'm wrong but it states "This custom cut adhesive film secures the display panel to the frame of a Google Pixel 6a smartphone".
A bit wrong. On the side Pixel 6a has 2 seams, first right under display, and second under plastic frame. And if you check the whole documentation, this adhesive must be placed UNDER the plastic frame (How to Replace the Adhesive for Your Google Pixel 6a) . The screen must be TOGETHER with this plastic frame. My goal is glue display and this plastic frame.
@pavel80282
My mistake. Apologies.
Never heard of P7000 glue.
There's B7000 which is a clear glue and T7000 which is black but basically they're the same.
Some say that T7000 is better because it doesn't allow light from the LCD to get through. Don't know personally if this is correct.
No worries.
Which of these can be used in my case? Maybe you heard about some special instruction, how to do that?
Pavel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 172
