Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
iPhone 13 Pro Display is black?
Hey.
I just got my New display. But when i installed it its all Black. but you can here the phone is on? The company that sold it. Says 2 of 1000 it can happend to. Is it fixable on some way?
crwdns2944067:05crwdne2944067:0
Try shining a torch into the display. If the backlight isn't working, you should see something when the torch is shone on the display.
@bananakat12345 Sorry, that advice won't help; the iPhone 13 Pro uses an OLED screen where the individual pixels generate their own light, so no backlight is needed on that display.
Markus, have you tried the original display? If it still works the same as it did originally and the new screen doesn't, then it's most likely an issue with the replacement display. Let us know what happens with the old screen.
Might pay to check the ambient light sensor is connected before going for a new display
just tryied with the lamp on the mobile. but the screen is pitch black. not a sign of something but the phone works with the old display that is cracked
As I mentioned in the comments, the flashlight test won't help you with your phone, as that only works with LCD based screens, not the OLED display yours uses.
Anyway, outside of possibly bent pins on the connector of the new screen, there wouldn't be anything you could do to fix it. The screen is pretty much an integrated assembly and either works or it doesn't, so at this point it seems pretty definite that you need a replacement.
yes. i will send it back. So they send me a new one then
Markus crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 58
