Power on but no display
Try disconnecting all devices and peripherals and reconnecting them again. The most common issue is a faulty hardware. So, try replacing it or check the troubleshooting errors. You can also perform a System Restore.
First, if you have an external monitor you can connect it using a cable, if the monitor can display what is on the laptop then the laptop screen is damaged.
crwdns2942667:0crwdne2942667:0 56
