The Malibu was redesigned for the 2008 seventh generation. This generation of Malibu came in many trim levels: the Base (2008 only) (1SB), the LS 1LS (or 1FL for fleet models 2011 and 2012), the LT 1LT (or 2FL for fleet models 2011 and 2012), the Hybrid (2008 and 2009 only), and the LTZ 1LZ. Only the top-level LTZ trim package was fitted with clear brake light lenses with red LED lights, the balance of trim packages retaining red lenses with conventional brake light bulbs.
My dashboard will not work on a Malibu 2011
My dashboard will not turn on a 2011 malibu
The instrument cluster in your vehicle gets its power from the Cluster/Theft Fuse 10A located in the Body Control Module located under the center console. That power comes into the cluster on a red/white wire terminal 14 of the connector at the cluster. The cluster ground is supplied on a black/white wire at terminal 6. The ground wire terminates at ground point G201 under the center console. So check the fuse first. Then check for power at terminal 14 and check for good ground at terminal 6 at the cluster connector. The cluster operates by digital data supplied by the body control module on terminals 7 & 8
Mario Tafoya crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 117
crwdns2942667:0crwdne2942667:0 695
