Red power cord burned off
Have a dv40j3000ew/a2 dryer that burned out the heating element. Replaced the heating element and the two heat sensors and put dryer back together. When I plugged it back into wall to test it, it sparked and blew out the red hot wire where the plugged in red wire connects. I can replace the terminal end of the red hot wire but did I wire up one of the heat sensors incorrectly? Any advice would help. Thanks.
Hi @scotthubba80253
With the power disconnected from the dryer, use a DMM (digital multimeter) and check if there's a short circuit i.e. 0.00 Ohms shown on meter) between the red wire and the dryer chassis.
This is to see if perhaps a wire/wire connection is inadvertently touching the chassis. If it is the hard part will be finding where it is.
Unfortunately the service manual for the dryer doesn't have a wiring diagram but hopefully it may still be of some help.
scott hubbard crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 49
