The Shark Navigator Lift-Away Zero-M (ZU561) is a versatile vacuum with a detachable canister for easy cleaning of hard-to-reach areas along with a self-cleaning brush roll that prevents hair wrap and tangled debris.
I am adding an LED 120 volt Light to this model
where can i tap into the power wires the light will be right under the silver trim just below where it says Zero-M CLEANER HEAD Thank you kindly GorgeguyNW
After deciding that only needed the head light when the beater bar was active i tapped into the Blue and brown wires. They are very accessible as they travel fr om the circuit board over the hump AKA Suction outlet. The LED sits up above the beater bar viewing window this placement allows for the user to monitor the beater bar, when vacuuming the LED lights the pathway from 3 to 5 feet in front as well as 4 ft wide this path is visible even in direct sunlight. My Shark lift away is now upgraded and much easier to use.
Daryl Edward Doroski crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 91
