Why does my laptop abruptly shutdown?
I have post this in other forum such as TH and LTT. I have not yet found an answer.
I have an Avita Liber V Ryzen 7 AMD NS14A8 . This is an off brand from Hong Kong, i think?
Why does my laptop abruptly shutdown, black screen but the power is running and fan is spinning.
Action taken so far
  1. Soft format (Keep Personal File from Recovery Option in Setting)
  2. Hard format from BIOS screen. Remove everything
  3. Disabled Fast Startup
  4. Edit Power Setting From 100% to 90% at Processor Power Management
  5. Replace Thermal Paste
  6. Reseat the Display Connector Ribbon
  7. Unable to reseat RAM because its integrated to the motherboard
  8. Unable to reseat the GPU because its integrated to the motherboard
  9. Used external display. connect it to the HDMI (No Signal Detected)
  10. Disconnected power from the battery because its integrated as well. So i am on AC all the time
  11. I did the remove batter and hold power for 30 second
Funny observation
When i am on full screen on Warthunder, laptop dont power off. I can play for hours.
But the moment i am trying to watch Youtube or do some work on Microsoft Office, suddenly black screen. The power led is on. Fan is spinning to discharge heat.
HW Monitor records normal temperature range 50c~80c~
The only reason i chose this brand because its offering Ryzen 7 at such a price of MYR2400.
Any advice is highly appreciated.
It sounds closer to a driver issue than a physical one, unless if I am misunderstanding.
Can you confirm the laptop fully shuts down instead of the screen alone going black?
@axodouble It doesnt fully shut down. When i click on Shut Down at the power option, it will go shut down, animation then black screen. Power is on. and it will run until the battery runs out. unless i force shut down. and when i restart, network and bluetooth will be missing. i have to use a network USB thing.
Check if your BIOS is updated if your laptop shuts down. Look for the battery life as it may happen due to an old or faulty battery. Also, you can free up some space to avoid sudden shutdowns. Additionally, if there is over usage of laptop and background apps keeps running then it also harms the laptop.
i am unable to update the BIOS since AMI doesnt provide solutions to end user. I tried to follow the steps. Couldnt find any BIOS. Battery life is still new. 2021-2025? i think. But now i am directly using AC. How do i free up some space? The last time i use Glary Utilities 1 click, it wipe my drive. Luckily i keep my important files on external drive. there is no over usage. or background app. i will be writing some document on a word document or just watching youtube, it will black screen and power will be running until battery runs out or in this case, as long power is connected, it will run.
i have same laptop and same issue trying to figure it out for 4 years
things i could figure out
1) the laptop dosent show this error when ran on charger
2) it could be a faulty motherboard which is used in all the models
3) no issue like this in the i5 variant of this laptop so it could be issue of amd cpu with the motherboard
4) ssd could be an issue try replacing it
things that may solve the issue:
1) change power mode to battery saver/low power by doing this the issue is reduced 80% and does not power off
2) always use charger or carry a cheap type c powerbank to power it all the time
3) throw this $@$* away
Wendy6572 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 107
