Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
iPhone Black Screen and Flashes
My phone was exposed to water for no more than 6 seconds, but it had been fully submerged to a low depth. Immediately after, I had not thought much of it so I'd continued on with daily use for approx. 30 minutes. Then, I began to notice it functioning oddly and also received a water detected notif when I plugged it it, so I powered it off and let it dry.
The next time I went to turn it on, which (stupidly) was later that evening, I found that there were green lines going across the screen and it had either a bit of a purple tint or green tint to the screen. I powered it off, but, eager to get to work on a project for my education, I tried again the next morning and the screen was black even though it felt like it was responding to my touch sometimes, and notifications were coming through too as my watch was receiving them. I could also hear and feel things from my phone as well.
It's been like this for about 5 days, and I know I probably shouldn't have but have been powering it on occasionally just so I can check my notifications and help things with my fully functioning watch. Sometimes I can see the screen, but it is only normal for a second, then gets a purple-ish or greenish tint and/or lines on the screen. This was mostly in the beginning, and now it usually goes black.
Along with the first bit of issues I received an error that face id was not working and when it gave me the option to go to settings, it didn't take me anywhere helpful.
What can I do? Because it is water damage, I'm worried it may not be able to be professionally repaired.
Update- now the screen is black and hasn't turned on again so far but flashes or has green or white bars on it usually at the bottom.
Hi @jillhelp
Check the status of the LCI for your model. If it is red then water has entered the phone.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
Do not try to charge or to turn on your phone anymore and then remove the battery as soon as possible from the phone to minimize any further damage. Given that you have been using it for a while since the phone got wet, you can only try to see if it can be fixed
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 12 mini repair guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
@jayeff - I would check the LCI, but I can not open the sim tray. I already made another post on that if you would like to help with that too.
@jillhelp
Here's the ifixit iPhone 12 mini SIM Tray Replacement guide that may help. You may have to use a bit of force to eject it.
If still no good you may have to open the phone anyway. Perhaps the water has caused more damage than you thought.
Does the case seem to be swollen?
@jayeff No, it does not seem to be swollen. I have also never opened the sim tray
@jillhelp
What happens when you push the pin into the sim tray eject hole, does the tray come out even little bit e.g. enough to grab it with tweezers or to place a fingernail behind the edge of the tray to prise it out?
No, it doesn't come out even a bit. In fact, in my personal opinion it seems like the sim ejector pin doesn't go all the way into the pin hole.
Jill crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 150
