Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
any tips on plugging internal connections back into phone?
the aftermarket batt replacement terminal doesn't line up well with the female port. The wiring is longer than the factory batt and this excess wire tape complicates mating. I took it apart and now cannot make the batt male plug fit into the female port, I should have made the attempt prior to adhering the new batt into place.
any tips?
You might have gotten the wrong battery for your phone. The battery below should work with your model.
iPhone 12 mini Battery - iFixit
crwdns2886500:0Replace a 8.57 Wh battery compatible with iPhone 12 mini. 3.85 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$39.99
I ordered that battery, which is correct. The male terminal is a millimeter or less, longer than my stock battery.
it's also stiffer than the stock battery wire tape.
Ryan Jung crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 31
