Why wont my samsung frig turn on?
I get blinking lights on both sides of the water dispenser when I plug in the frig and it wont turn on - why ?
Here's the service manual for the refrigerator.
Go to p.63 to see how to run the Self Diagnostic function to hopefully find out what's wrong.
If there's an error code being displayed when running the diagnostics go to p.65 onwards to find out what to check.
Has your water filter been changed if not that could be your issue. In addition if you resently changed it is it installed correctly with any cover over the inlet ports on the filter removed from manufacturing? Try checking it by removing the filter look for any packaging material over the holes if none try resetting the filter. Hope this helps.
crwdns2942667:0crwdne2942667:0 140
