Laptop no light indicator during charging
Laptop don't power on
crwdns2889612:0crwdne2889612:0
0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 39
@albert74116 not charging or not turning on? Does it give you any sign of life? Any LEDs coming on? What have you checked? Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
