Dealing with broken clock -- Parts unavailable or absurdly priced
I'm looking for options on how to deal with this problem.
My first thought was to 3D print a piece to fill the opening, as the clock/timer is not needed to operate the stove or oven but I can't print a heat-resistant material.
I could use some ideas. Ideally ones that don't look like rubbish.
Thanks in advance,
Joe
P.S.:
Re: "Absurdly priced" -- The plastic sheet that goes over the lock is currently available at only one retailer and it's almost $150, before taxes and shipping. ⏎
Re: Unavailable -- The clips that secure the clock in place are entirely unavailable.
Well since you're talking about removing it, have you considered getting something like a flat piece of aluminum, maybe ⅛" thick, cutting it to fit over the hole where the clock sits? You take a Dremel or other sander and round/bevel the edges, then take a small diameter rivet and secure it on either side. If you paint it with spray enamel it should look good and aluminum and enamel can withstand the heat. Or you could get two small pieces of metal, use the rivets to secure them to the back of the material the hole is in with ½ of them sticking into the hole as a backer, then get a piece of aluminum the thickness of the material that hole is in. Trim it to fit nicely into the hole. Then rivet it to the backers you installed. Then, other than the rivets, it would be flush with what is there. And aluminum is soft enough drilling for the rivets should be easy. A coat of enamel and viola it should look pretty darn good! Cheapest/easiest way I know to do it since they want so much for parts.
josephmoniz75 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 118
